LOUD MOUSE wrote:If you have vise grip pliers get a grip on the tapered side of the sprocket (other side from lock nut.)
Put the pliers to the front of the head.
Use a flattened tool to drive the nut to the right.
Hit it hard!. ....................lm
I will give that ago thanks...Dave
lloydy1 wrote:Cant get this lock nut to undo!!! broken a tooth of the cam cog trying...:o( Ill have to get it to someone who has a bit more know-how than me.
CB72-77 Racer
G-Man wrote:Dave
It's not impossible to find a right hand thread nut. Very rare but not impossible.......
Thanks my worry...I don't like taking a hammer to any bit of machinery scares me to be honest. hammer = broken!!!
Need to find a cam sprocket now...I can see that being almost impossible.
Cheers Dave
I can help with a cam sprocket. PM me.
lloydy1 wrote:G-Man wrote:Dave
Cheers Dave
Newly painted frame and parts back
just collected the newly painted frame and parts ready for the build.
Ill get better pics as the rebuild progresses.
- Frame
- m_100_1542.jpg (60.1 KiB) Viewed 5844 times
- Tank Strap
- m_100_1543.jpg (52.81 KiB) Viewed 5844 times
- Front Guard
- m_100_1544.jpg (52.07 KiB) Viewed 5844 times
- Bottom Yoke
- m_100_1546.jpg (45.31 KiB) Viewed 5844 times
- Swinging Arm
- m_100_1548.jpg (50.39 KiB) Viewed 5845 times
Re: Newly painted frame and parts back
Dave
That's going to look really nice.
lloydy1 wrote:just collected the newly painted frame and parts ready for the build.
Hand made copper gasket.
One hand fashioned copper head gasket. Not perfect, but should do the job.
- Old Gasket on top of new.
- m_100_1550.jpg (71.34 KiB) Viewed 5748 times
- hand fashioned copper head gasket.
- m_100_1549.jpg (67.83 KiB) Viewed 5749 times
Lloydy1,
I used an adjustable c spanner to loosen the left hand thread cam sprocket nut. I blocked the cam sprocket with a piece of hardwood. Some sharp hits with a hammer on the C spanner did the trick.
https://www.flickr.com/gp/131927779@N07/Cf5m2L
The adjustable C spanner is similar to this one - you would need to check the size.
http://www.ebay.co.uk/itm/like/35117616 ... 0&ff14=108
GMcC
GMcC
- IMG_0069A.jpg (439.52 KiB) Viewed 5726 times
