Engine cutting out going up a hill
Hi all, my dream was running good, didn't ride for a few weeks, when I did, when I throttled to go up a hill, at low speed, the engine ran slow, no power, and died. Took the carb off and cleaned, tried adjusting it, got a big backfire. Also checked the screen in the petcock, which was clean and the gas cap. Any ideas would be greatly appreciated. thanks
cuts out when going up hill
Hi, thanks for the reply, I did check the vent, was clear, any other suggestions? thanks a lot
Could have been some water in the fuel? Sometimes if in a humid environment water can condense in fuel tanks. That is the only thing that would make sense to me considering it occurred while going uphill. Look in the fuel tank and see if you see a blob of water on the bottom of the tank. If so or even if not try to drain some of the fuel out of the tank with the bike on a slight incline and this may solve the water problem if you have one.
Good luck,
Jethro
Good luck,
Jethro
Rick,
Please edit in your location when you get a chance. Pull the plugs and check the color, clean and or replace them. You should also do Ed's tune up recipe, look in the yellow bar on the left, FAQs, then how do I tune my...........
Davo
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
How do I tune my factory stock motor on my CB72/77 or CL72/7
Hi Davo, I'm in Stillwater, mn. must be having a senior moment, can't figure out where the yellow bar is, left of FAQ for Ed's recipe. Could you help a little more to find it. thanks a lot.
