Engine cutting out going up a hill
rick miller
Post by rick miller » Fri Aug 12, 2011 8:15 am
Hi all, my dream was running good, didn't ride for a few weeks, when I did, when I throttled to go up a hill, at low speed, the engine ran slow, no power, and died. Took the carb off and cleaned, tried adjusting it, got a big backfire. Also checked the screen in the petcock, which was clean and the gas cap. Any ideas would be greatly appreciated. thanks
Rock160
Post by Rock160 » Fri Aug 12, 2011 8:54 am
Be sure to check the gas cap vent. If it clogs with corrosion or old gas/varnish it can create a partial vacuum in the tank. I fixed mine (non painted cap) by soaking it in mineral spirits and then hitting it with the air compressor.
rick miller
cuts out when going up hill
Post by rick miller » Mon Aug 15, 2011 5:09 pm
Hi, thanks for the reply, I did check the vent, was clear, any other suggestions? thanks a lot
Jethro
Post by Jethro » Mon Aug 15, 2011 7:26 pm
Could have been some water in the fuel? Sometimes if in a humid environment water can condense in fuel tanks. That is the only thing that would make sense to me considering it occurred while going uphill. Look in the fuel tank and see if you see a blob of water on the bottom of the tank. If so or even if not try to drain some of the fuel out of the tank with the bike on a slight incline and this may solve the water problem if you have one.
Good luck,
Jethro
Post by davomoto » Tue Aug 16, 2011 10:08 am
Rick,
Please edit in your location when you get a chance. Pull the plugs and check the color, clean and or replace them. You should also do Ed's tune up recipe, look in the yellow bar on the left, FAQs, then how do I tune my...........
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
cleg
Post by cleg » Tue Aug 16, 2011 3:23 pm
+1 on the tune up recipie, mine was way off. Excellent!!
'66 CB77 '75 Rd125
rick miller
How do I tune my factory stock motor on my CB72/77 or CL72/7
Post by rick miller » Sat Aug 20, 2011 12:54 pm
Hi Davo, I'm in Stillwater, mn. must be having a senior moment, can't figure out where the yellow bar is, left of FAQ for Ed's recipe. Could you help a little more to find it. thanks a lot.
