Kickstart lever arm issues
nevernotbusy
So my kickstart lever doesn't sit tight against the frame, it sorta flaps out and out on its own when not in use. Is this a bushing issue? I saw that there's a little clip holding the pin/bolt that keeps the arm on, is it a matter of tightening that bolt to get some of that tension back?
nevernotbusy
Floppy Kickstart
Thanks Lrutt! I think you mean these two parts. I haven't actually looked at it on the bike yet, so I'm not sure if its just a wonky spring that needs replacing or if these two parts are missing altogether. Thanks for the heads up!
- floppykickstart.jpg (59.32 KiB) Viewed 3206 times
nevernotbusy
Floppy Kickstart
Thanks Malcom, and BINGO! there's a couple on ebay:
http://www.ebay.com/itm/Honda-Kickstart ... a3&vxp=mtr
L
L
nevernotbusy
Resolved!
Thanks for the tip. Here's a photo of the kickstart lever back in action. The lever was missing a spring and ball entirely!
- kickstart_fixed.jpg (74.2 KiB) Viewed 3105 times
Re: Resolved!
Sorry for the caps!!!!!!!!!!!!!!!!!!!!
I RECOMMEND YOU INDEX THAT LEVER AT 11:00 WHEN FOLDED IN.
WHERE YOU HAVE IT WHEN YOU KICK IT THROUGH YOU WILL HIT THE INTERNAL STOP.
THAT WILL ALLOW YOU TO TWIST THE SPLINE END OFF OR SPLIT THE SHAFT AT THE OIL HOLE AT THE OTHER END.
YOU WILL FIND THAT INDEXED AT 11:00 THE LEVER WILL CONTACT THE FOOT PEG AND THAT IS HOW HONDA MEANT THINGS TO BE. ..........lm
nevernotbusy wrote:Thanks for the tip. Here's a photo of the kickstart lever back in action. The lever was missing a spring and ball entirely!
