Kickstart lever arm issues
nevernotbusy
Post by nevernotbusy » Tue May 06, 2014 8:08 pm
So my kickstart lever doesn't sit tight against the frame, it sorta flaps out and out on its own when not in use. Is this a bushing issue? I saw that there's a little clip holding the pin/bolt that keeps the arm on, is it a matter of tightening that bolt to get some of that tension back?
lrutt
Post by lrutt » Thu May 08, 2014 11:10 am
should be a small spring and ball that rests in a detent I believe to hold it in. Swing it out and look at the base and see if there isn't a small circular depression in the piece that attaches to the engine.
nevernotbusy
Floppy Kickstart
Post by nevernotbusy » Thu May 08, 2014 11:47 am
Thanks Lrutt! I think you mean these two parts. I haven't actually looked at it on the bike yet, so I'm not sure if its just a wonky spring that needs replacing or if these two parts are missing altogether. Thanks for the heads up!
malcolmgb
Post by malcolmgb » Thu May 08, 2014 3:28 pm
I think it's 16 & 24, 18 is a plastic bung.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
nevernotbusy
Floppy Kickstart
Post by nevernotbusy » Thu May 08, 2014 5:40 pm
Thanks Malcom, and BINGO! there's a couple on ebay:
http://www.ebay.com/itm/Honda-Kickstart ... a3&vxp=mtr
L
nevernotbusy
Resolved!
Post by nevernotbusy » Wed May 14, 2014 3:28 pm
Thanks for the tip. Here's a photo of the kickstart lever back in action. The lever was missing a spring and ball entirely!
Re: Resolved!
Post by LOUD MOUSE » Wed May 14, 2014 6:50 pm
Sorry for the caps!!!!!!!!!!!!!!!!!!!!
I RECOMMEND YOU INDEX THAT LEVER AT 11:00 WHEN FOLDED IN.
WHERE YOU HAVE IT WHEN YOU KICK IT THROUGH YOU WILL HIT THE INTERNAL STOP.
THAT WILL ALLOW YOU TO TWIST THE SPLINE END OFF OR SPLIT THE SHAFT AT THE OIL HOLE AT THE OTHER END.
YOU WILL FIND THAT INDEXED AT 11:00 THE LEVER WILL CONTACT THE FOOT PEG AND THAT IS HOW HONDA MEANT THINGS TO BE. ..........lm
nevernotbusy wrote:Thanks for the tip. Here's a photo of the kickstart lever back in action. The lever was missing a spring and ball entirely!
