Side cover trim
cadman
Side cover trim
Post by cadman » Thu Aug 31, 2017 7:15 pm
What's everyone using for the black trim around the side covers?
rrietman
Post by rrietman » Thu Aug 31, 2017 9:18 pm
basically there isn't any oem stuff. just monkey it up with hardware store as best you can. the buttons for the port side are easy. right side you need a thin strip glued in.
Good luck
Randy
Gaius M
Post by Gaius M » Fri Sep 01, 2017 12:30 pm
i used 1/4 inch vacuum line (black) slit down one side.
Post by Seadog » Fri Sep 01, 2017 1:14 pm
I used a windshield wiper blade, trimmed down to fit.
bbap
Post by bbap » Tue Sep 12, 2017 9:39 pm
Seadog wrote:I used a windshield wiper blade, trimmed down to fit.
I cut out a piece of rubber out of an inner tube. Works and looks fine.
CA78 - 3111XX - Frame
CA77E - 3161XX - Engine
Geoff Hastings
Re: Side cover trim
Post by Geoff Hastings » Thu Sep 28, 2017 10:11 am
cadman wrote:What's everyone using for the black trim around the side covers?
This is what I used, it's actually a rubber gasket that is used on aluminium window frames, on the panel with the recess it just pushes in and on the side that usually has the two rubber pads I glued it in position. So, just ask a glazing installer, it cost next to nothing.
Re: Side cover trim
Post by G-Man » Fri Sep 29, 2017 3:39 am
Nice!
