Side cover trim
Side cover trim
What's everyone using for the black trim around the side covers?
Geoff Hastings
Re: Side cover trim
This is what I used, it's actually a rubber gasket that is used on aluminium window frames, on the panel with the recess it just pushes in and on the side that usually has the two rubber pads I glued it in position. So, just ask a glazing installer, it cost next to nothing.cadman wrote:What's everyone using for the black trim around the side covers?
- image.jpeg (219.59 KiB) Viewed 3316 times
Re: Side cover trim
Nice!
Geoff Hastings wrote:This is what I used, it's actually a rubber gasket that is used on aluminium window frames, on the panel with the recess it just pushes in and on the side that usually has the two rubber pads I glued it in position. So, just ask a glazing installer, it cost next to nothing.cadman wrote:What's everyone using for the black trim around the side covers?
