LOUD MOUSE wrote:If it runs as well at speed as it does at idle I'd leave it alone...............lm
1964 Superhawk Project
Thank you, LM. I haven't developed an "ear" for the engine, so i'm always in doubt about the evenness of the sound. I'm going to fiddle with it a little bit more tomorrow, then take it for a ride. I've already put the tank back on. Afterward, I'll know more and I can check the plugs.
Feller your 2 statements are in conflict with knowing good or not so good.
Good luck. .......................lm
Seadog wrote:Thank you, LM. I haven't developed an "ear" for the engine, so i'm always in doubt about the evenness of the sound. I'm going to fiddle with it a little bit more tomorrow, then take it for a ride. I've already put the tank back on. Afterward, I'll know more and I can check the plugs.
I respect your knowledge, but sometimes don't understand your comments. I'm sure it's a failing on my part, but could you explain the conflict of my statements?
LOUD MOUSE wrote:Feller your 2 statements are in conflict with knowing good or not so good.
Fabricated and zinc plated a bracket and installed a Kohler rectifier/voltage regulator using the old rectifier location. I made a new wiring harness for it, shrink wrapped it and sealed up the old wiring connectors in case I or a future owner want to put the old rectifier back.
A Sachse electronic ignition is on the way. I should be installing it next week.
- IMG_1433.JPG (169.07 KiB) Viewed 1483 times
- IMG_1428.JPG (149.29 KiB) Viewed 1483 times
- IMG_1424.JPG (145.15 KiB) Viewed 1483 times
Nice work, Seadog.
Seadog wrote:Fabricated and zinc plated a bracket and installed a Kohler rectifier/voltage regulator using the old rectifier location. I made a new wiring harness for it, shrink wrapped it and sealed up the old wiring connectors in case I or a future owner want to put the old rectifier back.
