1964 Superhawk Project
Post by Seadog » Fri May 20, 2016 5:46 pm
Thank you, LM. I haven't developed an "ear" for the engine, so i'm always in doubt about the evenness of the sound. I'm going to fiddle with it a little bit more tomorrow, then take it for a ride. I've already put the tank back on. Afterward, I'll know more and I can check the plugs.
LOUD MOUSE wrote:If it runs as well at speed as it does at idle I'd leave it alone...............lm
Post by LOUD MOUSE » Sat May 21, 2016 4:26 pm
Feller your 2 statements are in conflict with knowing good or not so good.
Good luck. .......................lm
Seadog wrote:Thank you, LM. I haven't developed an "ear" for the engine, so i'm always in doubt about the evenness of the sound. I'm going to fiddle with it a little bit more tomorrow, then take it for a ride. I've already put the tank back on. Afterward, I'll know more and I can check the plugs.
Post by Seadog » Sat May 21, 2016 5:40 pm
I respect your knowledge, but sometimes don't understand your comments. I'm sure it's a failing on my part, but could you explain the conflict of my statements?
LOUD MOUSE wrote:Feller your 2 statements are in conflict with knowing good or not so good.
Post by Seadog » Mon May 23, 2016 9:35 pm
Fabricated and zinc plated a bracket and installed a Kohler rectifier/voltage regulator using the old rectifier location. I made a new wiring harness for it, shrink wrapped it and sealed up the old wiring connectors in case I or a future owner want to put the old rectifier back.
A Sachse electronic ignition is on the way. I should be installing it next week.
Post by G-Man » Tue May 24, 2016 12:45 am
Nice work, Seadog.
Seadog wrote:Fabricated and zinc plated a bracket and installed a Kohler rectifier/voltage regulator using the old rectifier location. I made a new wiring harness for it, shrink wrapped it and sealed up the old wiring connectors in case I or a future owner want to put the old rectifier back.
Post by Seadog » Tue May 24, 2016 7:00 am
Thanks, G.
G-Man wrote:Nice work, Seadog.
Post by Seadog » Tue May 24, 2016 7:24 am
I had a old Kisan volt/amp meter lying around and decided to temporarily install it to keep an eye on the new R/R's performance. I'll remove it ASAP.
IMG_1436 2.JPG (289.49 KiB) Viewed 1463 times
