Fitting Winkers to CB77
sixtiescycle
Post by sixtiescycle » Wed Nov 18, 2015 4:25 am
G-Man wrote:It's easy. You just combine a CB77 bottom half with the SL90 top half......
Won't work, the SL90 and winker type CB switch is wider than the non winker CB switch.
Dick Johnson
'61 CB92
'63 domestic CL72 Type 2
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
mcconnellfrance
Post by mcconnellfrance » Wed Nov 18, 2015 5:51 pm
Hi Dick,
Thanks for the clarification. Pity the bottom parts are not interchangeable between the SL90 and the CB77 but you saved me finding out the hard way!
What part is the unit on the left? It has the starter button hole. Have you modified it?
Regards,
Gordon
sixtiescycle
Post by sixtiescycle » Thu Nov 19, 2015 4:18 am
mcconnellfrance wrote:
Hi Dick,
Regards,
Gordon
Hi Gordon,
The part on the left is an SL90 top and a lower winker type CB77. I needed a CL winker switch for a CL72 and by accident found the SL90 bottom w/o the starter hole turned my CB switch into a CL. I will at some point make what you saw in the picture into a winker switch for my CB77 as I too would like to put winkers on it. I'll pull the lower part (SL90) from my CL and see if the casting can be modified to accept the starter button if you were to drill the hole for the button. I'll keep you informed.
Dick Johnson
'61 CB92
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
mcconnellfrance
Post by mcconnellfrance » Thu Nov 19, 2015 8:34 am
Hi Dick,
Thanks for the clarification. I am now on the hunt for a reasonably priced SL90 switch.
Let you know how I get on.
Brgds, Gordon
mcconnellfrance
Post by mcconnellfrance » Thu Nov 19, 2015 8:51 am
Another twist to this thread. On looking at CMSLs listing for the SL90, I see that the left switch has two sliders and a horn button. I wondering if anybody has tried this as a solution on the CB77 for the winner switch?
http://www.cmsnl.com/honda-sl90-motospo ... k3Su1_fXCQ
Post by Seadog » Thu Nov 19, 2015 11:51 am
That's the same as I posted earlier. However, G-Man posted the one before that that looks the part. See his link:
http://www.ebay.com/itm/NEW-NOS-HONDA-R ... ~5&vxp=mtr
mcconnellfrance wrote:Another twist to this thread. On looking at CMSLs listing for the SL90, I see that the left switch has two sliders and a horn button. I wondering if anybody has tried this as a solution on the CB77 for the winner switch?
sixtiescycle
Post by sixtiescycle » Thu Nov 19, 2015 2:27 pm
That left switch is probably the easiest, as it would match the right side. I pulled the bottom of RH SL switch and compared to the RH CB bottom. The problem here is the SL the wiring is external. The hole in the SL for the external wiring takes out the tapped hole for the clip that holds the starter button and would need to be welded closed, drilled and tapped. The squared notch in the CB unfortunately was cut before I got this. I plan on welding a piece back in. Next problem is the switch itself, it's closed in the center position and open in the other positions, only has two wires and you need three. Pretty sure you could use parts from a Hi/Lo dimmer switch and make this work.
Attached pics, CB is the one with square notch on the left.
Dick Johnson
'61 CB92
'63 CL72
'65 CL77
'66 CB77
'67 CB450D
'71 SL350
'71 XS1B
