Brickyard
Post
by Brickyard » Wed Oct 14, 2015 5:41 pm
G-Man wrote:Brickyard
Those pistons look pretty nasty. The oil ways you show in your video are there to catch oil flowing back down from the top end (cam tunnel) to provide a bit of feed for the main bearings. The main oil source to the main bearings is direct from the oil filter and is related with the oilway you point to at the front of the top crankcase.
I suspect you have debris in your oilways and this debris could be blocking flow into the crank and then up to the cylinder / piston area. The piston / cylinder lubrication comes as oil thrown of the crank / big end.
You really need to strip the motor and clean all those oilways tyou can find as well as cleaning
the the centrifugal oil filter and filter screen around the oil pump. If you can, you should get the crank stripped and cleaned, as well, No oil to that piston probably means that the oilways in the crank are blocked.
The debris from the 'dry' piston is going to make the situation worse.
G, as much as I don't want to do it, with your advice, my shopping list for this bottom end rebuild is:
1. Complete engine gasket kit
2. Piston kit
3. Hondabond
Is there anything I'm missing that you absolutely wouldn't do without? And that's beside known worn parts I haven't seen yet. Maybe there're parts in there you already know are going to need replaced?
Post
by G-Man » Thu Oct 15, 2015 3:22 am
Brickyard
I would start with the oil filter and work from there. Maybe you can work out wha is happening at that stage. As for pistons, it would be a good idea to get the bores inspected / measured first. Take off the pistons and try and feel what shape the crank is in. You may be lick with what you find.
Brickyard
Post
by Brickyard » Thu Oct 15, 2015 5:43 am
Will do. I'm out of town until Monday and the parts I've listed are on order. I'll get right to it when I'm back home.
Brickyard
Brickyard
Post
by Brickyard » Tue Oct 20, 2015 7:52 pm
Wiseco brand piston kit from classichondarestoration.com
- IMG_0188.JPG (280.98 KiB) Viewed 2755 times
Brickyard
Post
by Brickyard » Tue Oct 20, 2015 9:02 pm
Cam roller parts in every crevice...
- IMG_0190.JPG (104.31 KiB) Viewed 2748 times
Brickyard
