Transmission main shaft bearing
Husker45
Post by Husker45 » Sun May 20, 2012 6:12 pm
I bought a ball bearing 91006-422-004 on ebay to replace 91004-259-000 on the transmission main shaft. Upon arrival I find it is a sealed ball bearing. The size is right and it has the proper slot in the outer race. Is it OK to use a sealed bearing in this application? I am restoring a 1962 CB77 that was in my father-in-laws tractor repair shop loft. Thanks for any insight.
Hoosier Tom
Post by Hoosier Tom » Sun May 20, 2012 6:43 pm
If you don't remove the shields(seals) I don't know how the oil is going to bathe the ball bearings.
HT
mike in idaho
Post by mike in idaho » Sun May 20, 2012 6:46 pm
Just pry the seal off each side, with a sharp pointed tool (it will pop right off), and install it.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
Husker45
Post by Husker45 » Mon May 21, 2012 6:10 pm
Thanks for the advice. I will pop off the seals tonight. Hopefully.
