Restoration Of Front Shock Absorbers
jensen
Post by jensen » Fri Jun 04, 2010 12:29 am
Indeed, Honda says 10W, but a heavier (fork) oil will make the front end a bit better. 30W seems a little to heavy, but you can start with 15 if you think the forks are under damped. Ofcoarse fork oil is better then engine oil, and maybe it's wise to change the fork seals too.
Post by LOUD MOUSE » Fri Jun 04, 2010 9:23 am
I use the same oil in the forks as I use in the engine. ..............lm
jensen wrote:Hi,
Post by davomoto » Fri Jun 04, 2010 11:07 am
Fork oil is hydraulic oil, which is very high detergent oil. It also resists foaming, which effects dampening. One can add 1/2 - 3/4 inch pvc spacers in the spring chambers to help with bottoming, and run 15 - 20 wt fork oil for a much improved front end.
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
mobilyte
Post by mobilyte » Thu Jun 10, 2010 6:08 pm
the maintenance standards section of the honda service manual gives the cb72/77 fork oil capacity as 250ml.
later in the construction section of the same manual it says "there contains white spindle oil 220"
was this a typo or maybe a difference between early and late forks?
Post by LOUD MOUSE » Thu Jun 10, 2010 6:43 pm
Name of the oil put in the forks?. .......lm
mobilyte wrote:the maintenance standards section of the honda service manual gives the cb72/77 fork oil capacity as 250ml.
mobilyte
Post by mobilyte » Thu Jun 10, 2010 8:32 pm
i'm just repeating what the copy of the factory service manual states...
(if it matters, i was planning to use either mobil 1 synthetic atf or some of the extra benz atf i have)
LOUD MOUSE wrote:Name of the oil put in the forks?. .......lm
Post by LOUD MOUSE » Thu Jun 10, 2010 11:32 pm
Spindle oil as I know it is a utility oil which the machine industry knows has uses in certain area/locations of machines including bikes and rather than say 5W-30 Detergent they say white spindle oil 220.
Surely ya are aware that the fork oil in the early bikes was referred to as spindle oil and was/is fish oil.
Don't belive it!
Smell it when ya are the first to replace it. ............lm
mobilyte wrote:i'm just repeating what the copy of the factory service manual states...
