DAMAGED KICK SHAFT FOR THE C/CA/CB/CL72/77 ENGINES
Post by LOUD MOUSE » Mon Feb 02, 2009 3:32 pm
This is what happens when the kick shaft in a C/CA/CL72/77 engine isn't indexed at 11:00 o'clock. If it's at 12:00 or later the internal stop bolt will hit the big end and cause the splines to twist and eventually the spline end will shear off. Pic one is where the stop bolt hits and pic 2 is how the splines look as they first twist. ................lm
Re: DAMAGED KICK SHAFT FOR THE C/CA/CB/CL72/77 ENGINES
Post by LOUD MOUSE » Mon Feb 02, 2009 3:34 pm
Here is a pic of the big end. ..............lm
LOUD MOUSE wrote:This is what happens when the kick shaft in a C/CA/CL72/77 engine isn't indexed at 11:00 o'clock. If it's at 12:00 or later the internal stop bolt will hit the big end and cause the splines to twist and eventually the spline end will shear off. Pic one is where the stop bolt hits and pic 2 is how the splines look as they first twist. ................lm
RIDE IT DON'T HIDE IT!
britman
Post by britman » Tue Feb 03, 2009 4:59 pm
Perfect timing LM. I am put chain side back on last evening. Indexed at 11. Great info.
Spargett
Post by Spargett » Mon Dec 07, 2009 3:54 am
LM, can you please explain how to "index" it at 11 o'clock? Do you just have the kick start lever pointing at 11 o'clock when sliding the crankcase onto the threads?
mike horvath
kick shaft position
Post by mike horvath » Tue Dec 08, 2009 9:45 pm
Guess I got a small job tomorrow. My shaft is at 12 o'clock. "Indexed" I suppose means in the returned, relaxed state. My manual shows the kick arm at 11. Never really gave it much thought.
Thanks Ed.
Re: kick shaft position
Post by LOUD MOUSE » Tue Dec 08, 2009 10:27 pm
You are welcome. .........lm
mike horvath wrote:Guess I got a small job tomorrow. My shaft is at 12 o'clock. "Indexed" I suppose means in the returned, relaxed state. My manual shows the kick arm at 11. Never really gave it much thought.
Thanks Ed.
chico
kicker
Post by chico » Thu Dec 10, 2009 6:02 am
Is 11:00 right for CB 77, seems to far back for front kicking. In your subject title, LM, you include CB
chico(steve)
66 CB77
ride safe
