toastyhamster wrote:Sounds easy with the right tool, any recommendations?
CB72/77 Rear Shock - Spring Rates ?
toastyhamster
Trying not to appear stupid - would a normal coil spring compressor do the trick? Like this:
http://www.screwfix.com/prods/45986/Aut ... ressor-Kit
Or is there a specific tool for compressing shocks, cos my google mojo appears to be broken if there is.
Scottie
Those are for car springs, when you're replacing MacPherson struts.
Anyone got a source for a shock spring compressor? I'm gonna need one eventually, too. I haven't seen anything at my local Honda shop.
Just did a quickie search -- would one of these work on old Honda shocks?
http://www.bikebandit.com/product/1946
http://www.jcwhitney.com/PROGRESSIVE-SU ... _10111.jcw
I'm thinking the 2nd style would be better, as you can't always get to the spring on the old shocks.
Scottie
Scottie
'65 CL77 (in pieces right now...)
'70 CT70H
'71 Yamaha R5B
'77 Suzuki TC125
'70 CT70H
'71 Yamaha R5B
'77 Suzuki TC125
You are correct. The 2nd one is the same one I bought. ............lm
Scottie wrote:Those are for car springs, when you're replacing MacPherson struts.
Scottie
RIDE IT DON'T HIDE IT!
toastyhamster
It looks like the "hook" in that second tool goes through the top shock mounting hole and the shock collar goes below the tool and you then wind the tool so it pulls the shock up and the collar is forced onto the bottom of the tool and so frees up the collets. I reckon I can probably improvise something to do that using a vice, pity I can't find the tool for sale in the UK though.
You can never have enough tools!
