Hi
I rebuilt my 305 about 5 years ago. I put in new clutch plates but the clutch has not worked properly.
I know there is a solution to solve this. Can someone help me. I recently fixed the starter and new battery with rectifier also upgraded the head and taillights to LED.
The clutch slips cold or hot and I run only Honda oil. I believe I read about a kit that Ed had developed for slipping and the adjustment procedure.
Thanks in advance.
1963 Honda Dream clutch slipping
- sky.fred
- Contact:
Re: 1963 Honda Dream clutch slipping
There's no reason why the original clutch shouldn't work properly.
If a clutch slips, it's either :
- incorrect assembly (wrong number of discs or incorrect stacking etc....)
- incorrect adjustment (insufficient clearance, etc.)
- poor quality parts
- damaged or worn parts (the clutch shaft doesn't slide properly, the springs aren't too weak, etc.).
- Tim Allman
There's one other possibility for a slipping clutch that I can think of: the motor oil. Oils formulated to reduce fuel consumption in cars may cause slippage in wet clutches such as this one. While it used to be reasonable to choose a good oil that was intended for cars and trucks, these days you should be using one intended for motorcycles.
