1963 Honda Dream clutch slipping
Hondaboy
Post by Hondaboy » Tue May 28, 2024 7:19 pm
Hi
I rebuilt my 305 about 5 years ago. I put in new clutch plates but the clutch has not worked properly.
I know there is a solution to solve this. Can someone help me. I recently fixed the starter and new battery with rectifier also upgraded the head and taillights to LED.
The clutch slips cold or hot and I run only Honda oil. I believe I read about a kit that Ed had developed for slipping and the adjustment procedure.
Thanks in advance.
sky.fred
Re: 1963 Honda Dream clutch slipping
Post by sky.fred » Wed May 29, 2024 2:30 am
There's no reason why the original clutch shouldn't work properly.
If a clutch slips, it's either :
- incorrect assembly (wrong number of discs or incorrect stacking etc....)
- incorrect adjustment (insufficient clearance, etc.)
- poor quality parts
- damaged or worn parts (the clutch shaft doesn't slide properly, the springs aren't too weak, etc.).
Tim Allman
Post by Tim Allman » Thu May 30, 2024 12:21 pm
There's one other possibility for a slipping clutch that I can think of: the motor oil. Oils formulated to reduce fuel consumption in cars may cause slippage in wet clutches such as this one. While it used to be reasonable to choose a good oil that was intended for cars and trucks, these days you should be using one intended for motorcycles.
