Soda blasting
CB160, CB350, CB360, CB450
Jlovvorn
Soda blasting
Post by Jlovvorn » Thu Mar 14, 2013 8:53 pm
Can I soda blast the engine cases on a cb160?
Or are they painted and I will need to repaint if I blast them?
I can't get these things clean no matter what I do.
mike in idaho
Post by mike in idaho » Fri Mar 15, 2013 11:11 am
They were painted. You might want to go over them with paint stripper first, then blast them.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
Jlovvorn
Post by Jlovvorn » Fri Mar 15, 2013 3:07 pm
Thanks Mike!
Should I bother with stripping and blasting or just paint them and move on?
Super90guy
Soda or media blasting... BEWARE!!!
Post by Super90guy » Thu Apr 11, 2013 10:41 pm
As MrHonda Bill S & I will attest, be very judicious in purging all the oil journals & channels in your motor after media blasting. Any medium used can find its way into those small orifices, and the results (if not properly & thoroughly cleaned) can lead to disaster!! Trust me, any media used is highly invasive stuff. A good looking motor exterior is not worth the potential internal grief & parts failure you might incur if all those orifices & oil passages aren't thoroughly cleaned. Suggest you check with a competent engine builder, but I'd recommend using a pressurized solvent cleaning tank, air hose or other means of cleaning out every internal passage way you can find after media blasting.
Ron S>
Paul Strassmaier
Post by Paul Strassmaier » Thu Apr 25, 2013 11:16 am
I'm a soda blast guy, but I degrease the motor during assembly and then blast when it's all back together. I have a kit of parts I use to plug everything up on the outside of the motor so nothing gets in, and I just go for it. I haven't had any problems and I'm just afraid I'll leave some residue inside any other way.
I have been pretty happy with soda blasting, but I've noticed that earlier bikes are tougher to clean up. I've just started to see the wet "Vapor blasting" which looks amazing, so when the cost is right I may switch over.
Paul Strassmaier
CB72, CL72, CS72, CYP77
C71,JC57,D, 4E, Z50m
nortryder
Post by nortryder » Tue Jan 27, 2015 6:45 pm
Paul, What kind of blaster do you use?
Tim Allman
Post by Tim Allman » Sat Feb 07, 2015 10:38 am
It's worth mentioning that the 'soda' is sodium bicarbonate which is water soluble. The blasted parts can be washed in water and the problem remaining is the much simpler one of removing the water.
