Can I soda blast the engine cases on a cb160?
Or are they painted and I will need to repaint if I blast them?
I can't get these things clean no matter what I do.
Soda blasting
mike in idaho
Super90guy
Soda or media blasting... BEWARE!!!
As MrHonda Bill S & I will attest, be very judicious in purging all the oil journals & channels in your motor after media blasting. Any medium used can find its way into those small orifices, and the results (if not properly & thoroughly cleaned) can lead to disaster!! Trust me, any media used is highly invasive stuff. A good looking motor exterior is not worth the potential internal grief & parts failure you might incur if all those orifices & oil passages aren't thoroughly cleaned. Suggest you check with a competent engine builder, but I'd recommend using a pressurized solvent cleaning tank, air hose or other means of cleaning out every internal passage way you can find after media blasting.
Ron S>
Ron S>
- Paul Strassmaier
I'm a soda blast guy, but I degrease the motor during assembly and then blast when it's all back together. I have a kit of parts I use to plug everything up on the outside of the motor so nothing gets in, and I just go for it. I haven't had any problems and I'm just afraid I'll leave some residue inside any other way.
I have been pretty happy with soda blasting, but I've noticed that earlier bikes are tougher to clean up. I've just started to see the wet "Vapor blasting" which looks amazing, so when the cost is right I may switch over.
Paul Strassmaier
Paul Strassmaier
CB72, CL72, CS72, CYP77
C71,JC57,D, 4E, Z50m
- Tim Allman
