Replacment part for CL77 BUSHING, RUBBER, REAR CUSHION?
Hi, did anyone ever figure out what can be used to replace my worn out shock bushings that go into the swing arm? Part# 52483-273-000 Thanks
'67 CL77 (337, gears X'd)
'65 CB160
'65 CB160
It looks like these are the same measurements except the inner will need to be drilled out to 12mm. I know they are solid, I'm going to suggest they make a rubber re pop.http://www.ebay.com/itm/Honda-CB160-Swi ... Sw-CpYA6PF
- s-l500.jpg (7.35 KiB) Viewed 4650 times
'65 CB160
'65 CB160
mike in idaho
I've carved shock bushings from UHMW plastic rod. UHMW is a hard, self lubricating, plastic material that comes in various shapes and sizes. https://www.amazon.com/Molecular-Weight ... uhmw+1+rod I chucked a piece of rod in a lathe, bored the bolt hole then cut the od to a press-fit size. Parted off the pieces to the desired length. You might check with the machine shops in your area to see if any of them dabble in the stuff. If they don't they could probably turn out something for you, out of brass or aluminum stock.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
