66 cl77 oil leak inside the RH cover..?
barnbiketom
Post by barnbiketom » Mon Feb 20, 2017 3:15 pm
I installed ALL new seals but the leak remains. I do not think it is the vent tube spewing oil, but I'm ready to run it with it pulled out and outside just to see.
The leak occurs right away and is pretty bad, but when I remove the cover, none of the seals look like they are the culprit. I pulled the stator and that seal looks dry too.
I'm wondering if I'm blind or just dumb??
The clutch pushrod has no groove but was corroded. I polished it . The oil is laying all along inside the bottom after only 5 miles and is dripping out.
Post by G-Man » Mon Feb 20, 2017 3:19 pm
Clean and dry everything then apply some spray talum powder. That should show you where the leak is originating.
barnbiketom
Post by barnbiketom » Mon Feb 20, 2017 6:52 pm
G-Man wrote:Clean and dry everything then apply some spray talum powder. That should show you where the leak is originating.
Excellent tip.
I was about to do that when I pulled out the breather hose that comes from the head and routed it over to the LEFT side of the bike, .
The leak is now on the LEFT SIDE..the left is now soaked hahahhha oil and vapors are coming out of that hose especially when I run down the road. crap..
Talked to LM and he told me what to look for... i guess I wont be riding it to work thursday hahahahha
Post by LOUD MOUSE » Mon Feb 20, 2017 7:23 pm
He now tells me it is from the TOP VENT TUBE!
At tmes not any of the usual answers fit! ......................lm
Excellent tip.
mike in idaho
Post by mike in idaho » Tue Feb 21, 2017 12:02 pm
Has the head been off recently? If the baffle plate between the top cover and the head is installed the wrong way around it will tend to drool oil out the breather.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
barnbiketom
Post by barnbiketom » Tue Feb 21, 2017 4:45 pm
I pulled the end of the vent tube out from the RH case and rode it. lots of oil came out!!
1 remove engine
2. tear engine apart
3. find missing circlip on RH piston and YUUGE gouge in cylinder.
its always simple..
IMG_20170221_162022 (Small).jpg (19.08 KiB) Viewed 2937 times
barnbiketom
Post by barnbiketom » Tue Feb 21, 2017 4:50 pm
mike in idaho wrote:Has the head been off recently? If the baffle plate between the top cover and the head is installed the wrong way around it will tend to drool oil out the breather.
couldn't be that simple.. hahaha
I hate working on my own stuff, I can't charge myself enough money to keep me sane.
going to change my middle name to pissmeoff
