Hi All.,
I had bought a set of rear shocks from Thailand when I rebuilt my Scrambler. It wasn`t a good decision, after 1500 miles they are in pretty bad condition and developed this annoying squeaking noise. Does anyone here have any experience with these shocks? It looks identical to the original but can`t be dismantled the same way. Thanks for any ideas.
CL77 rear shocks from Thailand: how to dismantle?
apeonwheels
Assuming the shocks are crimped construction....
This is not really for the mechanic without machine tools but I wanted to rescue som genuine damper bodies. I put the damper in the lathe and machined off the crimp.
I then threaded the bodies and made some sleeve nuts like the early CL77 shocks....
apeonwheels
G-Man,
Thanks for your reply. I`m afraid I wasn`t clear when I described my issue. I can`t even disassemble the shocks. As you know well, the original version comes apart if you compress the spring and remove the closing end as two halves. On other types (not Honda) there is a pin that you have to pop out and the shock comes apart. In this one, there is nothing like this, and the closing end is one unit.
I think I`m just gonna rebuild the original Honda shocks. I learnt from one of your threads that you can buy the covers as new for a Girling that with a little modification can be adapted to the genuine Honda. So, basically you already solved my problem :) I wish I had seen that earlier, then I wouldn`t have bought this poor quality Thai replica.
- P1030996.JPG (68.92 KiB) Viewed 5726 times
- P1030997.JPG (51.05 KiB) Viewed 5726 times
- P1030998.JPG (68.21 KiB) Viewed 5727 times
- P1030999.JPG (75.55 KiB) Viewed 5728 times
apeonwheels
When you've compressed the spring cable tie it. Then when you come to rebuild just snip them. Obviously good quality man sized ones and plenty of them. Worked for me.
I had thought of putting them up in the lathe to restore but thought they might be to thin to screw cut.
Well done you for persevering.
