I'm wondering if anyone ever figured this on out. I recently installed a new clutch, greased everything up, routed the cable correctly and I still have a very manly clutch pull.
The clutch seems to be functioning properly, but is a very hard pull.
I don't know what else to do, except spend more time in the gym
Adjusting Clutch :: Very Stiff at Lever
Re: Stiff Clutch Lever
Do you have a OEM return spring?
Pic?. ...............lm
ramwing7 wrote:I'm wondering if anyone ever figured this on out. I recently installed a new clutch, greased everything up, routed the cable correctly and I still have a very manly clutch pull.
ramwing7
Beats me.
You referring to the spring that goes between the case and the threaded lifter. I'm going to be looking for a lifter soon because the hole in the lifter that the spring goes to is about worn through.
Could be the wrong spring though. Somewhere in this poor bikes life the mechanics tool of choice seems to have been a pipe wrench.
I have that part and would like a pic of the spring. .................lm
ramwing7 wrote:Beats me.
ramwing7
Clutch Adjustment-Stiff Clutch
Never posted pics here. But gonna try.
They seem to have come out as attachments. That work?
- clu1.JPG (48.22 KiB) Viewed 3692 times
- clu2.JPG (50.53 KiB) Viewed 3695 times
Re: Clutch Adjustment-Stiff Clutch
Doesn't look like the OEM springs I have. ....................lm
ramwing7 wrote:Never posted pics here. But gonna try.
mike in idaho
Look at the angle between the cable and the release arm in the picture, it's past 90°. That means, to release the clutch you have to pull hard enough to pull things into almost a straight line. Back off the cable adjustment until the cable and the arm form a 90° angle with the clutch lever pulled all the way to the grip. Then turn the center adjuster to take up most of the free-play. Adjusted this way, you will have maximum mechanical advantage to release the clutch.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
