CB72 woes - Crank case
jensey
Post by jensey » Sat Aug 27, 2016 11:30 am
Be very careful with the black cables (speedo and rev). You are very lucky to have those.
Same for the aluminium front fender ! Both possible brittle, but unique parts, only for the early bikes (61 and early 62).
Post by LOUD MOUSE » Sat Aug 27, 2016 12:02 pm
I see what you describe very often.
Actually I would like to see under the oil filter and clutch.
I offer that clutch which I machine and make ready for a good ride. ................lm
CeeBee72 wrote:The history of this engine is that a rebuild was attempted by somebody who did not know what they were doing and got in such a mess they never finished rebuilding it (or cleaning it our properly - the sump still had bits of pistons in it and the oil filter housing was packed solid with ???) Luckily it was not run with misaligned parts or wrongly fitted parts. The original crank that was in there had two different can rods - one with a slit and the other two holes in the crown of the little end for oiling.
I got hold of a shift shaft but the arm (24711-268-030) is in a sorry state as you can imagine.
Is this the view you want?
Where do I shop for the clutch?
CeeBee72
Post by CeeBee72 » Sat Aug 27, 2016 12:39 pm
Here you go LM. The engine is now split so if you need to see a particular feature you will have to let me know and I will take some new pictures.
How much for the clutch please. I have not yet measured or checked the original plates so may have to spend more anyway :-(
Almost getting near selling the children (at 31 and 26 they get most upset by this)
sm oil clutch side of engine.JPG (114.76 KiB) Viewed 2791 times
Post by LOUD MOUSE » Sat Aug 27, 2016 3:55 pm
Thank you again.
This case has the early lower case.
The issue without the Primary Chain Tensioner.
I recommend you install the issue with the tensioner as it was installed to lessen the chain whip.
Any of the later cases will install perfectly. ...............lm
CeeBee72 wrote:Here you go LM. The engine is now split so if you need to see a particular feature you will have to let me know and I will take some new pictures.
CeeBee72
Lower engine case damage
Post by CeeBee72 » Wed Aug 31, 2016 2:08 am
I have had a go at soda blasting the lower crank case only to reveal more destruction. I am guessing this is more damage from earlier attempts to work on this engine. It may explain why the alternator was covered in oil as it probably acted as a crankcase pressure vent. Another case for JB Weld?
sm lower engine casing damage.JPG (51 KiB) Viewed 2706 times
Re: Lower engine case damage
Post by LOUD MOUSE » Wed Aug 31, 2016 6:53 am
That is the reason oil was there.
Did you read my above statement?. ..............lm
CeeBee72 wrote:I have had a go at soda blasting the lower crank case only to reveal more destruction. I am guessing this is more damage from earlier attempts to work on this engine. It may explain why the alternator was covered in oil as it probably acted as a crankcase pressure vent. Another case for JB Weld?
CeeBee72
Crank case
Post by CeeBee72 » Wed Aug 31, 2016 9:56 am
Hi LM. yes I did but I have not been able to locate one along with the tensioner gubbins so I have to go with what I have.
