Here's today's silly question:
How do you keep the side grip/handle on the left side of the frame from moving? I've tightened it as much as I can and even put rubber tape between it and the frame, but it still rotates after putting the bike on the main stand a few times. The parts lists show some sort of packing under it, but that's long gone.
Any suggestions?
Frame Side Grip (Handle)
- image.jpg (65.98 KiB) Viewed 3171 times
Re: Frame Side Grip (Handle)
I use 600 grit black wet/dry sandpaper.
I cut it 11/2 inch wide then fold it with the grit out.
Wrap it around the frame tube then install handle. ...................lm
Seadog wrote:Here's today's silly question:
Any suggestions?
Thanks, LM, I'll give it a try.
Edited 7/14 to add:
I tried this and it seems to be working, so far. Thanks again, LM.
Edited 7/14 to add:
LOUD MOUSE wrote:I use 600 grit black wet/dry sandpaper.
dragonfly888
