1964 Superhawk Project
Post by LOUD MOUSE » Tue May 24, 2016 8:04 am
Ya got me curious.
Where did you contact the wires?. ..............lm
Seadog wrote:I had a old Kisan volt/amp meter lying around and decided to temporarily install it to keep an eye on the new R/R's performance. I'll remove it ASAP.
Post by Seadog » Tue May 24, 2016 8:53 am
Kisan's Charge Guard uses a current detector that is connected to battery negative and all other negative connections are made downstream of it. It also has a battery positive connection to power it. An RJ-11 jack connects the detector to the meter.
LOUD MOUSE wrote:Ya got me curious.
Post by LOUD MOUSE » Tue May 24, 2016 9:49 am
I like that connection.
Where could I get one?. .................lm
Seadog wrote:Kisan's Charge Guard uses a current detector that is connected to battery negative and all other negative connections are made downstream of it. It also has a battery positive connection to power it. An RJ-11 jack connects the detector to the meter.
Post by Seadog » Tue May 24, 2016 10:05 am
https://kisantech.com/mag/chargeguard/cg-25.html
LOUD MOUSE wrote:I like that connection.
Post by LOUD MOUSE » Tue May 24, 2016 10:49 am
Thanks.
I'll collect the monies from parts sales and get one.
Looks like a really easy test of the charge system. ..................lm
Seadog wrote:https://kisantech.com/mag/chargeguard/cg-25.html
Post by G-Man » Tue May 24, 2016 11:35 am
I like the look of that. On my 1961 CB72 someone had neatly grafted a Lucas ammeter into the headlamp for a similar purpose.
Post by Seadog » Tue May 24, 2016 11:57 am
Happy to help. I'd help with parts sales too, if you have a good right side muffler....
I was just looking at the on-line manual for the ChargeGuard and see that they've improved the current sensor. It no longer has the copper tabs. I think that's a good thing.
LOUD MOUSE wrote:Thanks.
