Grease gun question ?
mike in idaho
Post by mike in idaho » Mon Mar 02, 2015 8:29 pm
R100 wrote:
mike in idaho wrote:Use one of these: http://www.jensonusa.com/!Ab6uitZUgCDCE ... ort-Nozzle , works with any style zerk fitting.
It seems to have a needle point. Does that have a spring and retract?
No, it just comes to a point, matches the hole in the grease fitting. Also pretty handy when you need to squirt out a little dab of grease to hold an o-ring or a side cover gasket in place during assembly.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
R100
Post by R100 » Tue Mar 03, 2015 9:15 am
Thanks Mike.
Unfortunately the shipping charge to Canada doubles the price.
I E-mailed Duralco to see if they have a Canadian dealer.
carabener
Post by carabener » Tue Mar 03, 2015 2:49 pm
A seller used to sell on ebay metal grease guns exclusively for CB77's 7-9 nipples. They still sell a cheapie CB77 grease gun from time to time.
In the meantime, the solution to your priceless kick start side covers being reduced to crap and breaking from non-lubrication is simple.
SO HERE'S THE FREE MILLION DOLLAR TIP:
It's called a "reverse nipple" grease gun.
Where to find one cheap????????
Ebay or your local shop:
They're used on Chainsaws to lubricate bar tip sprockets hundreds of times everyday all over the world.
The Dualco's are ok, look nice, expensive, and a pain in the a-- to load with grease and pressurize-(get working). I've got a couple laying around on the pain in the a-- shelf somewhere.
Stihl makes a nice cheap one I use on the chainsaw or the bike.
Easy to load, works immediately pumping grease, used it for 20 years so far.
Buy both and see which one you use more...
R100
Post by R100 » Tue Mar 03, 2015 3:25 pm
carabener wrote:A seller used to sell on ebay metal grease guns exclusively for CB77's 7-9 nipples. They still sell a cheapie CB77 grease gun from time to time.
I have a plastic grease syringe that came with my Stihl. Is that what you mean?
mike in idaho
Post by mike in idaho » Tue Mar 03, 2015 8:14 pm
carabener wrote: The Dualco's are ok, look nice, expensive, and a pain in the a-- to load with grease and pressurize-(get working).
Actually, mine is a Lincoln, looks just about the same as the Dualco. I drilled and tapped a 1/4 inch thread in the top for a grease fitting, I fill it with my big grease gun, no mess and no air bubbles.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
carabener
Post by carabener » Wed Mar 04, 2015 3:33 am
The Stihl is a black metal tube with a red plastic protective cover over the nozzle and red end cover over the grease filler area. Other people make a look alike greaser too. eg Forester/poulan
The Texas made dualco is pictured below at work on a CB77 if you get one be sure to get directions with it, or call the factory and they will happily send you them.
BEST #2 GREASER gun cb77.JPG (34.63 KiB) Viewed 4745 times
mike in idaho
Post by mike in idaho » Sun Mar 15, 2015 6:49 pm
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
