Head bolt tightening
garncarz
Post by garncarz » Tue Apr 08, 2014 6:08 am
Can the head bolts on a CA78 be tightened while the engine is still in the bike?
Tinman
Post by Tinman » Tue Apr 08, 2014 6:36 am
Unfortunately no. When you do torque them, start in the middle and work way outboard, crossing your torque pattern. Torque value is 16lbs. I think loudmouse torques his to 20+ lbs.
garncarz
Post by garncarz » Tue Apr 08, 2014 8:23 am
Tinman wrote:Unfortunately no. When you do torque them, start in the middle and work way outboard, crossing your torque pattern. Torque value is 16lbs. I think loudmouse torques his to 20+ lbs.
I also read that they should be re-torqued after the engine has been up to operating temperature. So the procedure is: Drop the engine, torque the bolts, reinstall the engine, ride, drop the engine, re-torque the bolts, re-reinstall the engine?
Well that just sucks now doesn't it. Thanks, Soichiro.
Tinman
Post by Tinman » Tue Apr 08, 2014 10:05 am
Yes it does! Some re-torque after the 1st or 2nd heat cycle, some have waited till 500 miles to re-torque.
You should have it down after dropping the engine the 2nd time, piece of cake. Good luck.
garncarz
Post by garncarz » Tue Apr 08, 2014 12:22 pm
The shop manual calls out yellow and white cap nuts. My 47 year-old set is all the same color - rust. What's the difference? Any need to replace the old cylinder nuts?
Thanks again for all the help!
garncarz
Post by garncarz » Mon Apr 14, 2014 11:34 am
garncarz wrote:The shop manual calls out yellow and white cap nuts. My 47 year-old set is all the same color - rust. What's the difference? Any need to replace the old cylinder nuts?
The "yellow" nuts have copper washers and the "white" nuts have aluminum washers. Who'd have thunk?
garncarz
Post by garncarz » Mon Apr 14, 2014 11:46 am
Well, I got up my nerve and dropped the engine yesterday. Everthing looks pretty good inside. I didn't measure them but the cylinder walls are bright and shiney with no scratches. Lots of carbon on the heads and piston tops (soft toothbrush and aircraft paint stripper).
While I am at this point, is there anything I should do before it goes back together? Anything in the pictures look amiss?
Oh, you really want to make sure that you have a firm grip on the cam chain masterlink clip so it doens't fall down into the crank case. Ask me how I know.
