Motor can not turn , can not use Kick start ,
up100
Post by up100 » Sun Dec 01, 2013 2:41 pm
up100 wrote:
Rickytic wrote:Aup, G-Man has given you a good lead on the penetrating oil. Most auto parts stores carry penetrating oil, just ask the sales clerk for it. When you put it in, soak it real good, you can't really get too much in the hole. Penetrating oil usually comes in an Aerosol can, spray it into the spark plug holes and let it sit, the more, the better.
To answer your question, PB Blaster is the name of a product used for unsticking rusted metals etc.
Let us know what model bike you are working on so we can visualize what you might have to do. If you can, pictures work well for help.
Thanks
Tic
Hi Ricky
I am working on honda C77 1961 press bar , I have attach some pictures
Well see another week how is going , I will let you know , hope it is ok ..
http://farm3.staticflickr.com/2851/1115 ... 06bd_b.jpg
http://farm4.staticflickr.com/3798/1115 ... 128c_c.jpg
http://farm3.staticflickr.com/2811/1115 ... e3aa_z.jpg
http://farm4.staticflickr.com/3707/1115 ... 1427_b.jpg
Post by G-Man » Sun Dec 01, 2013 4:32 pm
Aup
That is an excellent project! I have your bike's American sister. A 1960 C77 with tubular handlebars. I also have a 1960 C72 with pressed steel bars.
Good luck, my friend!
C77 - A by graham.curtis, on Flickr
C72 As bought.jpg (41.87 KiB) Viewed 4424 times
up100
Post by up100 » Mon Dec 02, 2013 1:49 pm
G-Man wrote:Aup
Hi G Man
Your one they are excellent too, hope our project will be done , I am working on the Engine at the moment ,very sad I have not get garage to keep the bike , well see next week if the solution can help ,
I do not know that much about the engine , but I wanna try,,,
Cheer
Up
up100
Post by up100 » Sun Dec 08, 2013 4:26 am
Hi Guys
Sad news , the Engine did not turn , I am going to put transmission oil in there ,
Watch on YOUTUBE
http://www.youtube.com/watch?v=F7EBKRyW ... jQ&index=2
What you guys think ???
Give me idea
Aup
sarals
Post by sarals » Sun Dec 08, 2013 12:50 pm
That was an entertaining video! That fella had an interesting idea on unsticking that engine. I'm hardly an expert, but looking at the photos of your engine suggests to me that you probably have a LOT of corrosion inside of your engine, if the outside is any indication. I gathered from the video that the method suggested in it would work on a "mildly" stuck engine, with clean cylinder bores. An engine with badly corroded internals might need to be torn down and repaired before that engine would turn over.
Graham - wow, you pick some challenges! However, I am even more impressed with your work when I see what with you started with!
up100, good luck!
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
malcolmgb
Post by malcolmgb » Mon Dec 09, 2013 6:10 pm
Just take the engine out and start stripping it, it isn't going to run in its present state anyway.
This is my CL engine at the moment, the left cylinder is well corroded the right piston will move but it pushes the barrel up on the seized left piston.
http://instagram.com/p/hq0ee_Lf7z/#
Sorry but Instagram turned picture 90degs but I think you can see my method anyway, I have used Coca-Cola to try and break corrosion.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
hondadreamca77
Unsticking Engine
Post by hondadreamca77 » Tue Dec 10, 2013 7:39 pm
One last try...
Pull spark plugs and shoot oil down cylinders. Leave plugs out for now.
Pull off side stator cover on right side of engine.
Cut up an old rubber inner tube and wrap it around the stator then put a chain wrench around wrapped stator.
Using a breaker bar CAREFULLY rock back and forth several times. CAREFUL you don't want to snap the crank shaft end at stator.
Should loosen. If not time for tear down.
Worked for me on CA77 engine that sat up 30 years and was locked and looked to be in same shape as yours when I started. These old Honda's can be real rough but still want to run with just a little encouragement. Such a great engine design. Next you can sno bol the gas tank and then tackle the petcock (ugh). It's all doable.
68' 305 Dream, 75' Honda 750-four, 74' Honda CL 125, 72' Honda CA 70, 80' Honda Passport, 74' Aerimachi Harley Sprint 125, 64' Yamaha 90.
