Hi everyone
What should I check if it the Motor can not turn , Unable to Kick start at all, Gear can change fine.
Please if anyone has idea ,please let me know.
Cheer
Aup
Motor can not turn , can not use Kick start ,
Rickytic
up100, how long has the bike been sitting? Have you ever been able to turn it over? What's the history on the bike? If the bike has been sitting for a long time, you might try removing the spark plugs and putting some penetrating oil in the cylinders and letting it sit for a week or so, maybe even longer. After you think you have it soaked good, try putting the bike in 4th gear and rocking the tire back and forth. Let us know if that works. There is other stuff you can use, such as PB Blaster, many on this forum have used that to help get pistons unstuck.
Hi RickyticRickytic wrote:up100, how long has the bike been sitting? Have you ever been able to turn it over? What's the history on the bike? If the bike has been sitting for a long time, you might try removing the spark plugs and putting some penetrating oil in the cylinders and letting it sit for a week or so, maybe even longer. After you think you have it soaked good, try putting the bike in 4th gear and rocking the tire back and forth. Let us know if that works. There is other stuff you can use, such as PB Blaster, many on this forum have used that to help get pistons unstuck.
Thank you very much , I just bought the bike from friend but he does not know about the engine , I think the bike has sitting for long time ago.
How much of penetrating oil should I use , how the oil look like ?
If it is working I will let you know.
PB Blaster , what is it?? can you explain please ??
Regards
Aup
Aup
Try this for penetrating oil.
http://www.tooled-up.com/product/plusga ... wwodzF4A7g
What bike are you working on?
Rickytic
Aup, G-Man has given you a good lead on the penetrating oil. Most auto parts stores carry penetrating oil, just ask the sales clerk for it. When you put it in, soak it real good, you can't really get too much in the hole. Penetrating oil usually comes in an Aerosol can, spray it into the spark plug holes and let it sit, the more, the better.
To answer your question, PB Blaster is the name of a product used for unsticking rusted metals etc.
Let us know what model bike you are working on so we can visualize what you might have to do. If you can, pictures work well for help.
Thanks
Tic
Thanks
Tic
HI G ManG-Man wrote:Aup
Thank you for this info I am working on Honda dream C77 1961 press steel bar.
I have bough this product before I put it in today well let you know in next week
Hi RickyRickytic wrote:Aup, G-Man has given you a good lead on the penetrating oil. Most auto parts stores carry penetrating oil, just ask the sales clerk for it. When you put it in, soak it real good, you can't really get too much in the hole. Penetrating oil usually comes in an Aerosol can, spray it into the spark plug holes and let it sit, the more, the better.
Thanks
Tic
I am working on honda C77 1961 press bar , I have attach some pictures
Well see another week how is going , I will let you know , hope it is ok ..
