Quick question and hopefully with a quick answer:
Will a cam sprocket from a CL work on a CB?
Ie. 14320-268-030 and 14320-268-040
Thanks
                    CL vs CB cam sprockets
				Merz64cb77
67' CB77
66’ CB77
65’ bomber
68’ hellcat
						66’ CB77
65’ bomber
68’ hellcat
Cam sprocket.
Yes, they are the same.
I suspect the latter of the two part numbers you quote will be a last issue cam sprocket with shallower splines. This won't interchange with either CB or CL camshafts unless you have the matching (late) spline pattern.
If your camshaft will fit he sprocket then it will work.
Just be aware that the C/CA sprocket, although it looks much the same uses different bob weights and springs to give a different advance curve. Using one of these in either a C or CL engine could give you low speed running issues but possibly not bad enough to be obvious.
				Merz64cb77
Cam sprockets
Hi DJM,
So you are saying they are the same but different? I can see if I can purchase the splines too
Thanks
Thanks
67' CB77
66’ CB77
65’ bomber
68’ hellcat
						66’ CB77
65’ bomber
68’ hellcat
Re: Cam sprockets
Only the CA is different (bigger bob weights). CB and CL are the same.
Merz64cb77 wrote:Hi DJM,
Thanks
'60 C77 '60 C72 '62 C72 Dream  '63 CL72
