Clutch Lever Perch Removal.
BradCA72
Post by BradCA72 » Tue Jun 26, 2018 12:43 am
I just purchased a 1965 CA72 and I need to replace the clutch lever perch. Do I have to remove the horn button, high/low beam switch assembly? How do I get the perch past the wires that go to the switch. Thank you in advance.
casamere
Post by casamere » Tue Jun 26, 2018 3:39 am
Oh that's a good one...you can cut the old one off it's getting the new one on that's the problem.
Re: Clutch Lever Perch Removal.
Post by G-Man » Tue Jun 26, 2018 4:19 am
Dismantle the switch - disconnect the wires in the headlamp and pull them through.
Then you can pull off the perch, re-thread the wires & reassemble.
BradCA72 wrote:I just purchased a 1965 CA72 and I need to replace the clutch lever perch. Do I have to remove the horn button, high/low beam switch assembly? How do I get the perch past the wires that go to the switch. Thank you in advance.
BradCA72
Post by BradCA72 » Sun Jul 29, 2018 11:55 pm
Thank you, G-Man. I just found a new perch installed it using your advice.
Post by G-Man » Mon Jul 30, 2018 2:24 am
Great job and thanks for providing feedback.
BradCA72 wrote:Thank you, G-Man. I just found a new perch installed it using your advice.
