Post
by G-Man » Tue Jun 19, 2018 4:41 am
Greg
I think that's a silver paint available in the US. I put mine in clean and dry.
GregMcN wrote:When you replace the liners do you coat with anything. I think I saw krylon mention in a post but was not sure what that was.
Greg
AlanW
Post
by AlanW » Tue Jun 19, 2018 12:41 pm
Hi Greg, clean and dry is the way to go and check the liner is not below the gasket face when finished,
Al.
GregMcN
Post
by GregMcN » Tue Jun 26, 2018 2:36 pm
Barrel has been skimmed and needed 14thou/ 0.35mm removed from the base to make it flat. Question is do I need to do anything to compensate for this?
Greg
Post
by G-Man » Tue Jun 26, 2018 3:26 pm
Greg
You could check piston to head clearance with plastigauge or just fir an extra base gasket.
GregMcN wrote:Barrel has been skimmed and needed 14thou/ 0.35mm removed from the base to make it flat. Question is do I need to do anything to compensate for this?
Greg
GregMcN
Post
by GregMcN » Fri Jun 29, 2018 10:17 am
Thanks Graham,
I was thinking along similar lines and I am tempted to try and make a thicker base gasket as I have in any case to modify the standard ones to fit the 350cc liners.
Greg
GregMcN
Post
by GregMcN » Sat Jul 14, 2018 11:25 am
Bike is back together and the home made thicker base gasket with the skimmed barrel base is not giving any obvious problems but the bike still has oil leak(s).
I think the worst is coming from the RHS and think either the main output shaft or the clutch pushrod seals. Not totally sure as no obvious visible damage and leak seems less evident at idle.
Both seals are new but I did use equivalent sized seals rather than model specific items.
Question is whether it is realistic to replace these seals without splitting the cases again?
Greg
Post
by G-Man » Sat Jul 14, 2018 1:27 pm
Greg
It can be done but will be more satisfactory if the cases are split.
Can you tell whether the leak is coming from the shaft or the case?
Clean everything off and thoroughly dry it. Then dust some talc over the area and watch what happens when you run the engine.
You may have shaft or case damage so you just need to find out which.
GregMcN wrote:Bike is back together and the home made thicker base gasket with the skimmed barrel base is not giving any obvious problems but the bike still has oil leak(s).
Greg
