Air screw
That's typically the starting point.
After the engine is fully warm, adjust the idle mixture screw to achieve the highest idle speed, then go richer ("in" if the screw is an air-bleed, "out" if it's a fuel-bleed) until you hear the RPMs just start to drop.
The idle mixture adjustment on the CA's carb is an air-bleed - so you would want to turn it "in" slightly after reaching the maximum idle speed.
Then adjust the idle back to the proper speed with the idle speed screw.
Thank you.jkv357 wrote:That's typically the starting point.
You will most likely be pretty close with 1.5 turns out, but the optimum setting will change with fuel type/octane/seasonal blend, air temperature, etc.
If you notice the idle is lower than usual, that can mean it's time to make a slight adjustment to get it back to the optimum setting.
As temps drop you will need to richen the mixture and vise versa.
