Need help with this part number
Hey Guys, I have a Honda OEM 37 tooth Rear Sprocket with Part # 41201-268-810 written in marker. Anyone know model and year. Center hole is 2 & 15/16. Bolt holes are 3 & 1/8 apart and 4 & 3/8 across. The sprocket has a goove runinng around the bolt circle (maybe back side). Thanks in advance, Scram64
15/32 is what I got from this site. Check it out when you get a chance. You have to use 1961 as the year to get CB72 fische.
http://www.nielsens.com/fiche_select.as ... &year=1961
