CB77 brake cams
Kaiser Karl
CB77 brake cams
Post by Kaiser Karl » Mon Nov 27, 2017 12:14 pm
Good evening gents
Again thanks for both your replies. The new !inings are indeed 4mm thick, well done for that info. For Al, I tried both the old and new cables without any difference. I didn't have this issue with the original Honda linings at 4mm; I was concerned about the adhesive being past it hence having them relined. This would suggest that something else is amiss, would you not agree, and oversize linings wouldn't be the answer? As I said, the cable is adjusted until the thread is almost out of the holder at the foot rest and not even drag?😣 I've been away for 5 days and no email link so later this evening I'll go out to the garage and look again. There are only 2 cams, 2 shoes, 2 springs in the thing, what is there to miss😭
Cheers
Kaiser
DJM
Brake adjustment.
Post by DJM » Mon Nov 27, 2017 1:03 pm
Not much to miss for sure.
If you're certain you have the arms assembled correctly with the dots all lined up why not try putting your old shoes back on again just as a reference.
I must say I don't think you will ever get the brakes working well with 4mm thick linings, why not take them back to the place that did them and ask them to do them again, properly this time.
Kaiser Karl
CB77 brake cams
Post by Kaiser Karl » Mon Nov 27, 2017 2:10 pm
DJ.
I did use the old shoes but same result! David Silver sells aftermarket and original shoes but I don't think they would make any difference. As I said, this scenario has materialised since taking the brake to bits for chroming the linkages and lining the shoes. I feel I'm looking at it but not seeing the problem😕.
Kaiser Karl
CB77 brake cams
Post by Kaiser Karl » Tue Nov 28, 2017 5:41 pm
DJ
Using oversize linings end getting the machining done looks like a logical suggestion; however the brake was OK before I stripped it at 4mm, just the years old bonding material worried me. It's the fact that now with new linings there's nothing like it should be. Would 1mm make such a difference? A bloke known on the forum suggested the footrest may be incorrectly fitted but it compares with his photograph! It's a mystery time and really frustrating.
Re: CB77 brake cams
Post by G-Man » Tue Nov 28, 2017 6:34 pm
How about posting some pictures of the bike and the brakes / cables?
You are doing something g wrong, we have to fathom what the pat is....
Kaiser Karl wrote:DJ
Kaiser Karl
CB77 brake cams
Post by Kaiser Karl » Tue Nov 28, 2017 6:39 pm
Hi Guys
I'll do my best to post pictures. Problem is I'll have to read up or look at how to do this. I can only use my mobile to do this. If it ain't metal coated in oil I'm stuck!!!!
Leave it with me G
mike in idaho
Post by mike in idaho » Tue Nov 28, 2017 8:21 pm
Maybe you should try advancing the splines on the levers, one spline past the dot.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
