                    Big bore question
				GORDON BROWN
Big bore
Hello Everyone
With CB350 pistons you also have to change the valve pockets as they are a different angle / position ( not sure if you need this with a std. road cam? ) and shorten the skirt as the stroke is longer on the 72/77.
For racing they ( and the head ) need quite a bit of work to get enough compression, though people including Yoshimura have used them.
Charles, I should have a pair of useable ASSO pistons if you need them for the racing.
Gordon
SAFOJ
Gordon
SAFOJ
- moondoggers
I have the Bore-Tech 358 kit and valve spring kit from http://www.rdvalvespring.com/spring-kits.html  Gobs of torque and compression in my 66' 305 Scrambler. A whole different feel with this set up.
									66' CL77, 63' CB77, 73' Jawa 350/ model 362  Californian 65' Jawa 250/model 590 07' Moto-Guzzi 1100 Griso
						- moondoggers
The Jawa is especially rewarding to ride on the back roads in my local, a  solid dependable machine. I exercise all 3 bikes weekly with 40 mile round trips.
- Trio resizded1.JPG (170.59 KiB) Viewed 3641 times
				oldbikedude
				supervision
