Can someone offer any tips on installing tank pads on a CL77?
Which would be the better end to start with? Narrow end or wide end. Would liquid soap ease the installation process?
Would warming the pads make them easier to install?
Any help would be appreciated.
Thanks,
Gary
Tank pads
When restoring these, I bead-blast them first to remove the dirt and glaze, then apply ArmorAll liberally to the front and rear. This restores the original black sheen and also lubricates the material for easier installation. It doesn't seem to matter which end you start from, but warming them with a hair dryer definitely helps a lot. The same treatment applies to the steering damper boot. For those, you may even need to immerse them in very hot water first to avoid tearing.
Gary,
I just cleaned mine up with soap and water, started on the fat end and worked it around the tank to the pointed corner and slipped it over. It took me abot 10 mins to do both sides. I will say that my pads were pretty pliable before I started though.
Ron
Ron
Ron Cribbs
1966 CL77
1965 CB160
1974 Triumph T150V
1966 CL77
1965 CB160
1974 Triumph T150V
