Tytronic electronic ignition help?
- David M. Lyon
TYTRONIC installation on CB/CL 72/77
I have a short video on YouTube of how to install the TYTRONIC ignition kit. The original instructions are impossible to follow so I made a set of instructions that might help you and a wiring diagram.
https://youtu.be/yKPwMUnbRU8
- Tytronic wiring.jpg (65.13 KiB) Viewed 3734 times
Dr. Frankenstein
- Tim Allman
- David M. Lyon
- Tim Allman
- David M. Lyon
jdmachinist
Tytronic Electronic Ignition problems
Thank you for posting these instructions!David M. Lyon wrote:Here are the instructions I revised to install the TYTRONIC ignition kit.
I installed a Tytronic Electronic Ignition on my 1965 CA77.... used the instructions supplied, not good but would get someone in the right direction.... i also used these which was a lot easier to understand.
After mounting and wiring everything up, it did not work :-(
Using a Test light to set timing, the light stays on the whole time. I was wondering if that was just a fluke, so i spun the motor and no spark at all.
Just messaged "Old_Honda" on Ebay. Going back to points for now so i can ride when the rain stops.
It is frustrating that i had to wait 2 weeks to get this from China then it was a bad one.
hopefully better luck next time.
