ca77 valve adjustment on new engine
win1906
Post by win1906 » Thu May 25, 2017 11:21 pm
so i have rebuilt a ca77 engine following bill silver engine rebuild book.everything was real good until i got to valve adjustment.as i understand the ca77 engine is a 360 with both pistons at top dead center when the stater is on (t).i have the cam dot on top.so what side valves do i adjust first and then rotate 1 turn and adjust the other side.
easy305
Post by easy305 » Fri May 26, 2017 4:06 am
Adjust the tappets on the side which has both valves closed,then as you say rotate engine through one complete revolution and set tappets on remaining side
easy305
Post by easy305 » Fri May 26, 2017 4:09 am
Make sure you have the 360 engine (one set of points) as the earlier engine (two sets of points) is different
win1906
Post by win1906 » Fri May 26, 2017 11:24 am
thanks for the reply but the head was completely taken apart so both sides have the valves completely closed.
Hahnda
Post by Hahnda » Fri May 26, 2017 12:18 pm
If your cam and rockers are back in then the valves on both sides can't be closed unless you have the adjusters backed all the way off.
win1906
Post by win1906 » Fri May 26, 2017 2:08 pm
correct the rockers were taken apart and cleaned.so the adjusters are backed off.
Post by LOUD MOUSE » Fri May 26, 2017 7:14 pm
Which earlier engine do you mean?. ..........lm
easy305 wrote:Make sure you have the 360 engine (one set of points) as the earlier engine (two sets of points) is different
