Mysteriously not starting on otherwise well tuned Dream 305
There's more to 'cleaning the carb' than simply checking that the jets are clear. The carb should be completely stripped (all jets, floats, rubber removed). Then soak in lacquer thinner (not carb cleaner, solvent, etc. -- lacquer thinner!) for 20 min or so, then blow out with compressed air.
After soaking be sure to give the air-screw orifices a good blast with the air.
How to check if your pilot circuit is plugged: Once you get the bike running, use the idle screw to set the idle. If it won't idle at low rpm, set the idle a little higher. If turning the air screw has little or no effect on the idle speed, the pilot circuit (low speed circuit) is plugged.
That would also explain the hard starting, as the engine is getting no fuel when starting.
Try putting some gas in a hand sprayer, shoot a small amount down the carb throat and try starting it. If the bike starts, runs briefly and dies, it's the carb. If the engine still won't run, it's electricical.
dreamneworleans
Thanks.. new plugs didn't do it.. but it still rumbles a bit when I try to start it.. something is cutting it off at that point.. do you know how to check the condenser?casamere wrote:The condenser boosts your spark it's only a small unit but it plays a major role in starting. By all means try a new set of plugs then you know that is covered. A condenser can fail anytime without warning. I'm afraid it's down to checking everything that is connected with the firing process.
Dr. Frankenstein
- jleewebb
valves?
Have you adjusted valve clearances recently? Quick subjective compression test would be to remove one spark plug, crank it over, replace it and remove other plug and crank over again...Does starter spin more freely on one side than the other?
'62 CB77. "It's a rider."
dreamneworleans
So the new plugs did not work.. It wants to start.. rumbled a little more today when I tried. How do I actually test the condenser and start solenoid.. I don't know where else to look...casamere wrote:The condenser boosts your spark it's only a small unit but it plays a major role in starting. By all means try a new set of plugs then you know that is covered. A condenser can fail anytime without warning. I'm afraid it's down to checking everything that is connected with the firing process.
Any thoughts are helpful. Thanks
dreamneworleans
Re: valves?
Sorry. I just saw this post.. Thank you. I will try that test... There is a local guru that helped me tune it up and fix a couple of things about a year ago and I believe he adjusted the valve clearances. Unfortunately, he no longer has his mobile service anymore. I am not above having someone come in to help me out, but it is hard to find those people.jleewebb wrote:Have you adjusted valve clearances recently? Quick subjective compression test would be to remove one spark plug, crank it over, replace it and remove other plug and crank over again...Does starter spin more freely on one side than the other?
Thanks
