Late CL77 clutch and front brake cable availability?
Tim Allman
Post by Tim Allman » Sun Apr 09, 2017 4:35 pm
Another possibility is to have the cables custom made. The necessary hardware could be removed from your old cables and installed in the new ones. There is a place near me (http://wolfeworx.com/cable-control/) that does this work. Perhaps there is someone near you.
Geeky160
Post by Geeky160 » Sun Apr 09, 2017 6:34 pm
Thanks everybody for the help. I found what I think will work. When I have them in hand, I'll post the info. I can tell you that the Black Bomber front brake cable is one. The clutch is 020 NOS I found. He shows 2 left after me if his inventory sheet is up to date.
Geeky160
Post by Geeky160 » Thu Apr 20, 2017 4:56 am
I ended up buying these:
http://www.ebay.com/itm/Front-Brake-Cab ... dV&vxp=mtr
It was a little lighter in color that the NOS cable form Taylor. Also, the outer sleeve was more rubbery that what I'm used to.
And Taylor motorcycle had a clutch cable. I think he has 2 left.
http://taylormotorcycles.com/
