Late CL77 clutch and front brake cable availability?
Hi, did anyone ever find a source for these cables? Parts # 45450-273-020 and 22870-273-020 for the clutch. I need to replace them this time around. Thanks
- IMG_1387(1).JPG (123.04 KiB) Viewed 4000 times
'67 CL77 (337, gears X'd)
'65 CB160
'65 CB160
- barnbiketom
Scrambler Cycle: http://scramblercycle.highwire.com/prod ... agesize=12
I am pretty sure he is looking for the cables without the built in adjusters. I only have the ones with the adjusters. I have never tried it but it might be possible to remove the adjusters with some careful Dremel work.
I could also have some made without the adjusters but I haven't seen much of a demand so far.
Yes, my '67 needs the ones without built in adjusters. I think I found the clutch NOS. I have a high bar set that had the adjusters. I went to shorten them and remove the adjusters but botched melting on of new ends. There's a place here that will put ends on so I still may go that way if I cant find the brake cable.Hahnda wrote:I am pretty sure he is looking for the cables without the built in adjusters. I only have the ones with the adjusters. I have never tried it but it might be possible to remove the adjusters with some careful Dremel work.
I can't believe more folks haven't asked about these cables. I would have thought there would be more demand.
