On the brake side, the clip is welded onto the inside of the fender strut.  I think I recently saw the clip for the speedo side on eBay.
Edit to add:  here you go http://www.ebay.com/itm/NOS-Honda-44852 ... AS&vxp=mtr
You'll need a 5mm x 10 screw to mount the clip, part #93500050100a, also available on ebay.
                    Clutch Cable Routing
				texasgrape
Thanks Seadog!  I just saw the brake side didn't have a bolt hole like the speedo side, so I was wondering  . . . glad you cleared that up.  I found the horn tag and a good grommet!  I had them in a bag to be installed after paint.  Gotta find a rattle can to match horn cover and carb covers.  Will go to paint section later.
									1967 305 Dream, 2006 Triumph Rocket III
