Post
by G-Man » Wed Dec 14, 2016 11:46 am
Norfolk.......??
DJM wrote:Where on earth is Naarfk?
Tim Allman
Post
by Tim Allman » Wed Dec 14, 2016 2:57 pm
Is that like the famous brass band sponsored and named for Norfolk 'n Weigh?
adeskey
Post
by adeskey » Wed Dec 14, 2016 3:57 pm
Thanks DJM,
Naarfk is my attempt at humor, it is the phonetic spelling for Norfolk....or that's how it is pronounced (a lovely dialect by the way).
Anyhow, this front wheel..can you tell me more ? What is it about it that makes it non CB77?
More on the resto in that I decided to start on the engine, so the first thing was to make some plates to mount it onto a mobile stand and so I could then tilt it through 360 degrees. (see pic)
The oil was drained and the filter cleaned - only a small amount of crud - but I had fun getting the oil filter cover off, breaking 3 screwdriver bits with the impact driver. And I was being gentle...! Yes they were not impact bits, but I thought it should work.
Maybe this engine had not been apart for a very long time, or not at all.
- cb77 13dec16 004.JPG (195.59 KiB) Viewed 2909 times
- cb77 13dec16 013.JPG (140.03 KiB) Viewed 2909 times
Post
by Seadog » Wed Dec 14, 2016 4:30 pm
You need JIS bits/screwdrivers.
Post
by G-Man » Wed Dec 14, 2016 4:40 pm
The front wheel looks like it is from another bike. The CB72 / 77 has a bolted torque stay and the speedo drive is on the right hand side. The wheel you have has pressed brake arms whereas the CB72 are forged steel.
My guess for your wheel would be Suzuki Super 6 or similar, judging by the speedo drive, brake linkages and the slotted lug for torque reaction.
adeskey
Post
by adeskey » Wed Dec 14, 2016 5:10 pm
Thanks G-Man
I have been looking at my front wheel, here beside me, and noting that it agrees with what you said.... on checking the photo, which was the one on the advert, the wheels are different. The one in the picture is not the wheel that I received. So that is a good thing, in that I have the correct wheel.
Hurrah!
pemdoc65
Post
by pemdoc65 » Wed Dec 14, 2016 7:42 pm
I like that bracket that you used to attach the motor to the engine stand. I need to rig up one of those.
