Thanks - I don't mind seeing them, I like easy access. I used the oil manometer on my Kawasaki ZRX 1200 R, it had CV carbs on it, too, but they were not too sensitive - worked well.jensey wrote:Hi,
Nice vacuum ports. I placed them to the inside instead of outside. This way they are hard to see when looking at the bike. I also make them on my CB450's, also pointed inwards.
It saves a lot of hassle, especially on the early 450's (the carbs are known as very sensitive).
Very nice build anyway !
Dick Eastman
Dick Eastman
I did some plating yesterday [brake parts]; also made a front wheel collar and some swing arm pivot bolt washers, S/S; got the sprocket on, but the cover plate was warped, so I had to add some button screws to it.
My K&N filters arrived today - ordered them direct from mfr., p/n RC 0790. The tech at K&N said they will flow 100cfm each. I will oil them when ready to put in service.
- engine build 001 (Medium).jpg (69.27 KiB) Viewed 5951 times
- engine build 002 (Medium).jpg (70.79 KiB) Viewed 5951 times
- engine build 004 (Medium).jpg (82.41 KiB) Viewed 5951 times
- engine build 003 (Medium).jpg (69.95 KiB) Viewed 5951 times
- engine build 006 (Medium).jpg (70.82 KiB) Viewed 5951 times
Dick Eastman
Thanks - can't wait to see end result myself - that' why I call it "slowly but surely".Seadog wrote:Looking great. Can't wait to see the final assembly.
Have you considered buying a used starter motor wire from ebay just for the grommet you need? They're listed from $9 upward. Just a thought.
I may have to go to e-bay for the terminal cover - got the grommet covered. The only problem with 50 year old rubber parts is they are usually dried out and cracked. I may try to find a cover for a garden tractor app, as the wire is 6ga.
Dick Eastman
I installed a Sigma bicycle speedometer to my Kaw, and now they make them wireless. They have odo, trip odo, time, speed, avg speed, max speed. I plan to use one for this project. I designed and machined the bracket for the AutoMeter temp gage, as well - I really like their products. I plan to mount the AutoMeter tach centered above the headlight, and the Sigma offset, closer to bars.
- Copy of IMG_2558 (Medium).JPG (67.67 KiB) Viewed 5906 times
- IMG_2564 (Medium).JPG (68.23 KiB) Viewed 5906 times
Could this work?Dick Eastman wrote:I may have to go to e-bay for the terminal cover - got the grommet covered. The only problem with 50 year old rubber parts is they are usually dried out and cracked. I may try to find a cover for a garden tractor app, as the wire is 6ga.
http://www.ebay.com/itm/Starter-Motor-T ... Da&vxp=mtr
border0_3
Hi Dick,
Your doing some excellent engineering works there.
A couple of alternate sources for rubber boots.
http://www.ebay.co.uk/itm/1x-Durite-Ins ... 1731198233
http://www.ebay.co.uk/itm/1x-Durite-Ins ... 0963816027
Keep up the great work - regards Richard
