Speedometer cable direction of rotation under power.
Eljeef
Post by Eljeef » Sat Oct 22, 2016 6:55 pm
Hi folks. I have an issue with my Speedo. It doesn't seem to work. I disassembled and lubricated it and put it back together. I would like to spin it with my variable speed drill to diagnose but don't know which way to run the drill. Help!
1964-C77 305 Dream
2002 BMW R1150GS
Re: Speedometer cable direction of rotation under power.
Post by LOUD MOUSE » Sat Oct 22, 2016 7:06 pm
Try both.
One will work. ...............lm
Eljeef wrote:Hi folks. I have an issue with my Speedo. It doesn't seem to work. I disassembled and lubricated it and put it back together. I would like to spin it with my variable speed drill to diagnose but don't know which way to run the drill. Help!
Eljeef
Post by Eljeef » Sun Oct 23, 2016 7:14 am
LOUD MOUSE wrote:Try both.
Thank you. I was concerned about breaking it if I chose the wrong direction. I'll give it a shot.
1964-C77 305 Dream
2002 BMW R1150GS
Backyard
Post by Backyard » Sun Oct 23, 2016 2:06 pm
I took a peace of the speed cable and put it in a drill and had to run the drill in reverse to get the pseedo to work, the drill was going 60 mph.
Post by LOUD MOUSE » Sun Oct 23, 2016 3:10 pm
Now you know it works and as long as your drive at the wheel goes the same dorecton you will be good to go. ...............lm
Backyard wrote:I took a peace of the speed cable and put it in a drill and had to run the drill in reverse to get the pseedo to work, the drill was going 60 mph.
Eljeef
Post by Eljeef » Mon Oct 24, 2016 12:14 pm
Well, I tried it both directions and nothing happened. I'm not sure if the cable is making contact with the Speedo internals. I will have to pull it out and look further.
1964-C77 305 Dream
2002 BMW R1150GS
