CONTINUING clutch problems!!!CONTINUING clutch problems!!!I finished the rebuild of my '67 C77 last winter but have had on-going clutch problems.
The original clutch was sticking badly so I took it off, cleaned everything thoroughly, and put in new friction plates. Then the clutch would slip on hard acceleration, particularly in high gear, so I replaced the springs with heavier springs. Now the clutch is sticking badly again! It is also difficult to pull the clutch lever. The bike doesn't get used often but when it does, it takes some work and ###ing around to get the clutch to let loose. Do others have this problem? Is it the type of oil (10w 30 automotive)? Did I put in springs that are too heavy? Other ideas?
There is a later clutch assembly which reduces the amount of oil that gets to the plates. Look for a pressure plate with four holes in the pressure plate.
http://www.ebay.com/itm/HONDA-CA-72-77- ... ww&vxp=mtr This works with a mating centre http://www.ebay.com/itm/Honda-CB72-CL72 ... 2o&vxp=mtr Some notes from Honda UK on the later clutch.... ![]() G
Dianne, If your 10w30 bears the words "Energy Conserving"on the label, then friction modifiers are likely present. I had a friend who had a similar clutch problem. He changed his oil...problem solved. "If the women don't find you handsome, they should at least find you handy." Red Green
My oil didn't say anything like "energy conservation" or "friction modifiers" but I change it out for "motorcycle oil" and changed back to the original clutch springs after washing the clutch plates.
Took it out for a boot today and the clutch didn't appear to be slipping. We will see if it slips on the highway or sticks again.
