Rear Sprocket question 1966 CL77
bosscat
Post by bosscat » Sun Aug 21, 2016 6:40 pm
I bought a new 37 tooth rear sprocket for my 1966 CL77.
When I got ready to install it the center is too large & the bolt pattern is too large as well.
I haven't had any luck trying to locate a smaller version.
Does anyone know of a source for this type of sprocket?
Thanks,
Daryl
Re: Rear Sprocket question 1966 CL77
Post by LOUD MOUSE » Sun Aug 21, 2016 6:47 pm
Do you have the large brake bike?. ................lm
bosscat wrote:I bought a new 37 tooth rear sprocket for my 1966 CL77.
Thanks,
Daryl
bosscat
Post by bosscat » Sun Aug 21, 2016 7:20 pm
I have no idea.
How would I determine that.
bosscat
Post by bosscat » Sun Aug 21, 2016 7:22 pm
I would guess it would be small brake since the old sprocket has a smaller hole and bolt pattern than the new one.
bosscat
Post by bosscat » Sun Aug 21, 2016 7:24 pm
The original sprocket has a center hole a little over 80 mm in diameter.
If I remember right the new one is more like 87 mm in diameter
Post by LOUD MOUSE » Sun Aug 21, 2016 7:44 pm
Looking at the brake backing plate you will have either one or two levers with a rod between them. ........lm
bosscat wrote:I have no idea.
bosscat
Post by bosscat » Sun Aug 21, 2016 7:48 pm
Mine has 2 levers with a rod between them
LOUD MOUSE wrote:Looking at the brake backing plate you will have either one or two levers with a rod between them. ........lm
