CL77 front wheel hub rattle ??
skychs
Post by skychs » Wed Jul 20, 2016 2:29 pm
1967 CL77 305 Scrambler
I took the front wheel off, removed the tire and pulled off the brake and speedo assemblies. When I rotate the wheel by hand I hear what appears to be pebbles in the hub. The bearings and seal are still in place. Im a little concerned.
Any idea's?
chuck
skychs
noise
Post by skychs » Wed Jul 20, 2016 3:05 pm
I just spoke to a guy in MD who specializes in CL77's. He said the noise is rust rolling around the outer rim of the wheel. He explained the way the wheels are made/designed and he said it is very common but not an issue unless you have a ton of rust with gaping holes.
I feel a little better.
OldScrambler
Post by OldScrambler » Sun Jul 24, 2016 10:59 pm
Could also be a tiny pebble.................I have several wheels with that little 'rattle'............
Jangongo
Post by Jangongo » Wed Sep 07, 2016 4:31 am
You made me understand many stories up.
Rickytic
Post by Rickytic » Sun Sep 25, 2016 5:37 pm
If you don't like the noise, it can be fixed with very little effort. I had the same issue with mine when they came back from chroming. I drilled a very small hole in the outer rim and injected some epoxy (not a lot ) but just enough to coat the rust balls. When the epoxy dried, the rattle was gone.
